Victoria 7 Automatic preset on sale now!
News and announcements about Reality, for all editions
Postby pciccone » Tue Mar 08, 2016 11:53 am
Go beyond what you thought was possible in realism with this for Reality 4. Once installed, the preset will automatically adjust your materials whenever you add Victoria 7 to your scene. There is nothing to load. It just works.
To use this preset you will need Reality 4.2.1. If you need to update your Reality 4 installation, simply go to the .
This preset works with the Victoria 7 materials, the eyelashes variants, the eye shaders, the makeup shaders and the genitalia.
For just 3 days it's on sale at just $2.99.
Click to buy
arrow1
Re: Victoria 7 Automatic preset on sale now!
Postby arrow1 » Wed Mar 09, 2016 1:01 am
Does this Preset work Victoria 7 when imported and converted by Genesis 3 Updater in Poser 11? Cheers
Postby pciccone » Wed Mar 09, 2016 7:56 am
joaquimlopes
Postby joaquimlopes » Mon Mar 14, 2016 9:45 am
I have managed to do a render with the V7 preset but the genital preset is totally unusable - it renders as white (when rendering using iRay it renders correctly). This is a problem because I do some nude renders.
Postby pciccone » Mon Mar 14, 2016 9:52 am
Did you assign the V7 Genitalia mat to it?
joaquimlopes
Postby joaquimlopes » Mon Mar 14, 2016 10:31 am
Hi, Paolo.
Yes, I assigned the mat in Daz and in Reality, the materials tab shows the genitalia preset as V7Genitalia.
Postby pciccone » Mon Mar 14, 2016 10:49 am
Ok, I see that the material preview does not show it as all white. There might be some other causes. Do you see any error message in the Log tab of Lux?
joaquimlopes
Postby joaquimlopes » Mon Mar 14, 2016 11:18 am
I get no error messages in Lux.
Postby pciccone » Mon Mar 14, 2016 11:41 am
OK, thank you. Please send me samples of the result that you obtain via private mail usin thes forums.
Fram1963
Postby Fram1963 » Mon Mar 14, 2016 1:28 pm
The gamma setting on the image map used in the diffuse for the genitalia is set to 1.00 and should be 2.20 to match the torso setting. That is why you get that whitish coloring on the genitalia area.
Should the V7 Genitalia preset be updated to reflect this?
Cheers,
Lyne
:D
Return to “Reality News”
