A lot of products are coming now for Daz using instances as a short cut however this does not work for reality
is there any way around it or any thoughts on a patch to make this new system work for reality?
instances
Re: instances
You can't parent items into an instance
You have to have a separate instance for every object
YOu can't say, have a Vase with a Flower where the flower is a separate prop and is parented unter the vase
and have an Instance on the Vase
Daz Studio will replicate the whole thing but Reality will only export The Vase and not the whole thing
the long story is to create new instances(in this example of the flower), parent them to move them in place (if you parent an object and then Zero out Translation, Rotation, and Scale, it should place exactly the same spot) unparent them, group them all together, delete the original instancing to clean up the clutter (optional)
Re: instances
This might be worth a look https://www.daz3d.com/instances-to-objects
