The Light Emitter
PixelWrangler
Re: The Light Emitter
Postby PixelWrangler » Sun Mar 27, 2016 4:23 pm
Postby Marcel2586 » Mon Mar 28, 2016 7:29 am
You can use a color texture and set it to green, but you have to go very low in the gain. if you leave it at 1,0000000 your neon tube shows up white.
If you set the gain to, lets say, 0,0050000 the tube will be green. use bloom in lens effects to give it a little bit of glow. turn first all other lights off, use bloom and turn all the other lights on.
As from my experience, rendering emitters with textures is much better/faster and almost no render noise
This is a test only with colors and no texture.
Render time +/- 5 minutes
This is a test only with color texture.
Render time +/- 2 minutes
I have downloaded a Neon sign with a real black background.
Create a new plane and scale it. give it the neon sign texture.
In opacity use the same texture (click on the gear menu and select "Use Existing...")
Chose in the light emitter the Neon sign texture (click on the gear menu and select "Use Existing...")
This is the result (render time +/- 2.5 minutes
Postby pciccone » Mon Mar 28, 2016 8:13 am
Thank you Marcel for the detailed tutorial.
Postby Marcel2586 » Mon Mar 28, 2016 8:20 am
You are very welcome mr. Paolo.
just having fun and a good excuse to render.
But i have a question,
Why do emitters render very well and fast with low light settings and when you use mesh lights it is terrible?
Postby pciccone » Mon Mar 28, 2016 8:27 am
I'm not sure I understand the question. Can you give me more details and/or an example?
Postby Marcel2586 » Mon Mar 28, 2016 8:44 am
Same scene. One with mesh light rendered for 3 minutes and one with a plane turned into emitter.
The mesh light has more noise. Used a turquoise RGB color
The emitter less noise. Used a turquoise texture
Postby pciccone » Mon Mar 28, 2016 8:54 am
Have you checked with bot light sources being the same size and same position? The two examples show two different lighting setups.
Postby Marcel2586 » Mon Mar 28, 2016 9:46 am
Bummer! you are right. :lol:
Postby Fram1963 » Mon Mar 28, 2016 11:14 am
Thanks Marcel for this helpful tutorial!
Postby pciccone » Mon Mar 28, 2016 11:17 am
