Bump map, normal map and displacement map
Re: Bump map, normal map and displacement map
Postby fuzzy70 » Mon Apr 25, 2016 5:51 am
Easy mistake to make Marcel, I tend to do my tuts offline in a text editor then past them into a post. I still make some errors but not as many doing it that way, also a 2nd set of eyes reading it always helps as easily can miss things from staring at the same text over & over again.
The biggest problem I have is putting it in a way that others can understand & sometimes that fails spectacularly as the translation from my brain into words occasionally causes me problems.
Postby Fram1963 » Mon Apr 25, 2016 12:43 pm
Thanks Marcel for the nice tutorial!
olurtz
Postby olurtz » Thu May 19, 2016 5:07 pm
Thank you for the tutorial, I was about to start searching for the terms but I found your post :)
My question is, to get skin more wrinkly or lets say wrinkles at joints, I need a better bump map? Can I achieve this myself by editing lets say Victorias textures?
Thank you again for the tutorial
Best wishes
Postby Marcel2586 » Fri May 20, 2016 12:08 am
Yes, you can. but first you need to clean the texture before you make a bump map/normal map, especially with normal maps.
If you do not remove birthmarks and freckles, it can really mess up the skin. birthmarks could become deep holes.
