I could really use some help with SSS
vaden
Postby vaden » Tue Jun 26, 2018 7:19 pm
Hello,
I am working on a render and I have a real issue with SSS on a certain character. The skin is red and whenever I apply SSS, parts of the body come out with a blue haze over them, even though the next body part looks good. I have tried at least 6 different combos of SSS colors, changed metallicity, and even removed it, changed specular etc etc but the result is always the same. The hand and arm are over the areas and render great but the torso and hip regions and some leg gets the problem. I have synced every single skin part to the exact same settings to make sure that it wasnt the texture or odd setting. See below my example, the other two in the scene have blue skin and purple skin and they look amazing after adjusting SSS colors. I am at wits end, Ive ran at least 30+ different render tests , minimum 10 minutes each and let several go overnight to see if it clears but no luck. :|
