Reality Light Settings Not Xnsfring to LuxRender
Nyghtfall
Postby Nyghtfall » Sat Sep 10, 2016 10:26 pm
I'm working on a project that I have 13 light groups set up for in Reality. 10 of them are set to a color temperature of 2500. The remaining two are using RGB colors. Neither the color temperatures nor RGB settings are transferring to Lux when I start rendering.
I've saved the Reality scene several times, and tried deleting the project resources to force Reality to recreate them, but when I check the Light tab in Lux, all of the default settings are still in place, and I have to reconfigure them again, in Lux.
How do I make Lux to recognize my custom settings?
Re: Reality Light Settings Not Xnsfring to LuxRender
Postby sigstan » Sun Sep 11, 2016 4:04 am
Nyghtfall
Postby Nyghtfall » Mon Sep 12, 2016 1:59 am
Postby Gederix » Mon Sep 12, 2016 10:06 am
Ive seen this. Color temps do not carry from reality to lux. Never works for me, so I just dial in the colors once lux is up and running.
banditcameraman
Postby banditcameraman » Mon Sep 12, 2016 11:31 am
Just to verify and at the risk of asking something you've already done, is "Preserve Light Hue" in Scene Configuration checked? :oops:
Postby Gederix » Mon Sep 12, 2016 12:42 pm
Are you saying you have to select preserve light hue in order for the color temps chosen in reality to carry over?
Postby sigstan » Mon Sep 12, 2016 1:16 pm
Postby sigstan » Mon Sep 12, 2016 2:08 pm
You also used RGB, so let's take a look at that type of light.
To begin with RGB light is not really a good physical based light and can often be replaced by other types of light.
Using the same test scene as before, I change the mesh light to a yellow color:
I get the following result (CPU accelerated/Mono/Sobol):
Seems okay.
Now I don't know how you are using your RGB or if it is actually in view of the camera, but let us test with the sphere turned into a light using RGB.
Also okay. So I am not really able to replicate your issue.
If your lighting is not tied to geometry you could try to upload scene with just the light setup and I will be happy to take a look at it.
Postby sigstan » Mon Sep 12, 2016 2:25 pm
Nyghtfall
Postby Nyghtfall » Mon Sep 12, 2016 11:07 pm
I just tried all of the same tests. They rendered as expected. Now I'm wondering why the same functions had no effect on my project. Ah, well... it's rendering...
