How do I make the light emit from lamp/bulb props?
Tripp
Postby Tripp » Sat Jan 14, 2017 9:55 am
Hey :D I use Reality/Luxrender latest versions.
Until now I have only been using reality meshlights, placed behind my cameras. I have never lit up any light source prop on the scene, for example any kind of lamp. Usually I always hide any lamps on my scene when possible, cause I don't know how to light them up.
How can I start making the lamps on my scenes emit the light? Instead of always placing the meshlights behind the camera? Are there any tutorials on this?
Re: How do I make the light emit from lamp/bulb props?
Postby sigstan » Sat Jan 14, 2017 11:42 am
Depends on how powerful your light should be. You can either turn the bulb into a Reality light source or make it emissive.
If you want the bulb to emit a strong light, then it needs to be a real mesh light. This can be achieved by renaming the bulb object, so that it includes a RealityLight prefix like this:
  • RealityLightLampBulb
This will turn the bulb material into a mesh light, and you will find it in Reality lights tab. You will need to find the correct gain, that fits the scene and also prevent a burn-out of lamp shades etc.
If the light need not be strong, then you can make the bulb emissive. There is a tutorial about emissive lights here:
http://preta3d.com/forums/viewtopic.php?f=23&t=307
Tripp
Postby Tripp » Sat Jan 14, 2017 1:46 pm
Many thanks. In fact I was also trying to light up an monitor screen but I didn't mention it, but you gave me a tutorial directly to that!
Thanks again, I will try these tips out right now. If I remember, I will post some renders of my results :)
Postby MustangMike » Sat Jan 14, 2017 2:54 pm
Hey Niels, where do you rename the item you want to turn into a Reality light? In a modeler or in DS?
I've just used the preset in Reality "Convert to Light" from the right click menu.
Mike
Postby sigstan » Sat Jan 14, 2017 3:03 pm
MustangMike wrote:Hey Niels, where do you rename the item you want to turn into a Reality light? In a modeler or in DS?
Mike
You just rename the object in DS, but yes you can also use the "Convert to light" in Reality. Forgot about that option, since I usually handle this in DS before even going into Reality.
