I am having an issue when rendering in Luxrender.
The face texture doesn't matches the neck texture whenever i use bump map. happen on all skin
Using CPU acceleration only.
the strength is exactly the same for the settings but keep getting this mismatch need help with this
Screenshot with bump and no bump
Daz studio version 4.9.2.70
Luxrender version 1.60
Reality version 4.3.1.16203
Win 10 Pro 64bit
Texture face and neck mismatch
Last edited by kidanonymous3dx on Thu Feb 02, 2017 11:59 am, edited 1 time in total.
Re: Texture face and neck mismatch
Your bump settings do not match. The positives, one is .0005, the other is .0010, so twice the value.
Gederix wrote:Your bump settings do not match. The positives, one is .0005, the other is .0010, so twice the value.
Sorry that's wrong SS when i play around with the value, all the value is the same. added correct SS now
I assume you have checked in the Luxrender log that all bump maps are actually read and applied correctly (no missing files)?
But it is two different bump maps (face and torso), so there can be differences. Luxrender/Luxcore is a lot more demanding with the quality of bump maps than for example 3Delight. You probably need to lower strength on one of them to match the other. In this case more likely the SkinFace. Also consider changing the materials to Skin instead of Glossy. It will look more natural.
That's what I've been doing lower the strength on the skinface, I was able to get matching texture before tho its just bugging me that i can't get it to match lol
How does it look if you render in 3Delight?
I had a similar problem with some skin in the past and I contacted the vendor. She send me an updated version with "fixed" bump maps.
You can open the two bump maps and compare the two if they have the same brightness/contrast
it render fine in 3delight no mismatch
You might just call it a loss and use bump maps from another figure or better yet create some normal maps for the figure.
Users browsing this forum: No registered users and 6 guests
