Maybe permission issue - cannot import presets Mac OS Sierra
beyondx
Postby beyondx » Sun Mar 26, 2017 3:15 pm
Hello folks,
unfortunately I´m having an issue with importing presets.
Installing reality-plugin I also had to go the "command line"-way. This worked fine and I´m able to render with reality. The only thing that doesn't work is importing presets. When trying to import a preset according to the install-pdf the reality plugin crashes immediately. That way I´d like to ask where the presets-folder is located as I´m assuming that this might be a permission issue as well. I´d like to try to extend permissions on folders or files.
If there´s another way to make it work I´m open to another solution.
Operating system is Mac OS Sierra.
I miss the reality presets and hope someone can help me out.
beyondx
Re: Maybe permission issue - cannot import presets Mac OS Sierra
Postby pciccone » Sun Mar 26, 2017 10:32 pm
Sounds like a possible issue with the ACSEL.db file. I would suggest to delete it and re-install Reality.
beyondx
Postby beyondx » Mon Mar 27, 2017 2:08 pm
Thanks for the quick reply. I cannot find the ACSEL.db file. Where should it be located on a Mac ? (OS X 10.12)
Postby pciccone » Mon Mar 27, 2017 4:35 pm
It's in the ~/Documents/Pret-a-3D/Reality folder
beyondx
Postby beyondx » Sun Apr 09, 2017 9:45 am
Sorry for the late reply, but thanks a lot for your fast reply!
I just changed permissions on the ACSEL.db file and hey... it worked!
Issue solved.
Thanks again for the great support.
