OPENCL doesnt work with Radeon R5
chilliramen
Postby chilliramen » Fri May 12, 2017 8:17 pm
Hi all,
I am very new both in DAZ3D and Reality. I can't find how to make the OpenCL work in my GPU Radeon R5 M430.
When I tried to render a scene from DAZ3D, the LuxRender log said:
[2017-05-13 07:12:46 Severe error: 2] RUNTIME ERROR: OpenCL device selection string has the wrong length, must be 4 instead of 3
I don't really understand whether the Reality would read my GPU. While it mention AMD Parallel Processing, the lists seems to missed the AMD. It only mention ICore and Hainan. Please see attachment.
I already tried install AMD Driver, but the lists doesn't change. Is there anyway I can make the OpenCL worked?
Btw, I am sorry if I missed a similar thread with this kind of problem.
Re: OPENCL doesnt work with Radeon R5
Postby sigstan » Sat May 13, 2017 3:15 pm
chilliramen
Postby chilliramen » Sun May 14, 2017 4:38 am
Hey Sigstan,
My CPU-Accelerated tryout was very slow, even compare to usual IRay render. That maybe because I don't really try to change anything.
Thank you for pointing out things for newbie like me to follow. Let met get into it; and back for you later.
chilliramen
Postby chilliramen » Sun May 14, 2017 5:00 am
Postby sigstan » Sun May 14, 2017 10:22 am
Hi Chilliramen
The debug log should tell you which OpenCL devices Luxrender has detected. Sometimes it is an internal GPU that can might just be disabled, if not used anyway.
It is also in these cases possible to run a render after performing a slight edit on the scene *.lxs file.
If you look in the luxrender files for your scene there should be a *.lxs file. This file contains a section which will look something like this:
Renderer "luxcore"
"string config" [
"renderengine.type = PATHOCL"
"opencl.devices.select = 100"
"opencl.gpu.workgroup.size = 64"
The line in bold is the one that Luxrender for some reason is complaining about. This is a set of flags turning on/off your OpenCL devices, so the one signifies a device turned on. Luxrender apparently expects 4 devices here, but Reality is only supplying 3.
You can try to edit the file and add a zero to the end of the string (example 1000) and see if the scene can render. Simply go to the Reality directory and down into the Lux directory (typically C:\Program Files\Reality_DS\lux) where you will find luxrender.exe. Run the program and from File -> Open select the *.lxs file you have edited.
As to using CPU-acceleration it can be relatively fast, but it depends very much on your hardware. With CPU-acceleration and default settings (Mono-directional/Sobol) it should as far as I know render faster than iRay in CPU mode in most scenes.
For an intro to Reality rendering take a look at PlatnumK's tutorial:
jtarrier
Postby jtarrier » Mon Oct 09, 2017 6:10 am
