Can't create fog
thefett
Can't create fog
Postby thefett » Mon Oct 30, 2017 6:25 pm
Hi,
I'm following the tutorials, created a null cube with 12:12:12 scattering. Also tried cone and various other scattering levels and different light sources. Tried camera inside and out of volume and light inside and outside of volume. Tried fog volume on either inside or outside surface or both. Always get no scatter - renders like cube is air filled (with outside wall foggy if light source is outside it). Any ideas?
Re: Can't create fog
Postby PlatnumK » Mon Oct 30, 2017 7:47 pm
What are you Acceleration Settings & Your Scene Settings
thefett
Postby thefett » Tue Oct 31, 2017 4:22 pm
cpu-accel, no boost, 0 CL group
sobol, mono-directional. 1FF, noise unaware, 16 path length
Just tried no-accel, metropolis, bi-directional and got some fog - thanks!
Grrr... seems intermittent though. I merged new items into the same fog scene, scaled up the fog size and the fog went away again.
Looks like another key factor is having the camera outside the fog volume.
Postby PlatnumK » Tue Oct 31, 2017 8:48 pm
I good guide to read is the 'Reality Render Options' by Sigstan as it gives a good idea on what is supported in each of the various render modes
viewtopic.php?f=23&t=536
thefett
Postby thefett » Tue Oct 31, 2017 10:47 pm
Thanks - had a read through it.
Postby sigstan » Thu Nov 02, 2017 3:30 am
thefett
Postby thefett » Thu Nov 02, 2017 12:36 pm
Yup, thanks got that. Still having intermittent failures, but going with a good file and adjusting things one small thing at a time. So far so good.
Users browsing this forum: No registered users and 9 guests
