Instal of Reality fails
david2169
Postby david2169 » Fri Dec 08, 2017 3:50 pm
Hi
I have tried to install Reality on my Mac and keep getting the error message shown in the attachment, downloaded another installer to be sure the original one I obtained was not causing this, but the same error happens. Any clues, cures please...
Re: Instal of Reality fails
Postby PlatnumK » Fri Dec 08, 2017 11:12 pm
Right Click on the RealityInstaller.app and select Show Package Contents, Then Navigate to Contents/MacOS and Right Click on the RealityInstaller and select Open so that the installer runs from the terminal
david2169
Postby david2169 » Sat Dec 09, 2017 1:47 pm
Thanks PlatnumK that gets the install window up but there is no option to install once you click next on the agreement window which appears once you select open with terminal.
david2169
Postby david2169 » Sat Dec 09, 2017 1:49 pm
The attachments may make the reply to PlatnumK clearer
Postby PlatnumK » Sun Dec 10, 2017 7:51 am
In the 1st screenshot click on Change where it says 'Location Of DAZ Studio' and select the folder where you have DAZ installed. If you have installed it in the default location then it would be 'Applications/DAZ 3D/DAZStudio4 64-bit'
david2169
Postby david2169 » Sun Dec 10, 2017 8:54 am
Thank you so much PlatnumK for leading a blind man by the hand and showing him that attention deficit is often self inflicted. Many thanks and it works fine now
Postby PlatnumK » Sun Dec 10, 2017 8:20 pm
your welcome
