Incomplete exports
rionoirble
Incomplete exports
Postby rionoirble » Mon Jun 04, 2018 10:18 pm
- Daz: 4.10
- Reality: 4.31
- LuxRender: 1.6
- No acceleration
- Windows 10 64-bit
- Product causing the issue seems to be Ultimate Grass & Meadow Worldbuilder (Daz)
When I go to render scenes using the above product, Reality fails to export the entire file and ends up causing a bunch of errors (Error: 41, missing instance GUID). The file continues to process but ends up looking miserable obviously. I am able to process the files with Iray.
Rivaliant
Re: Incomplete exports
Postby Rivaliant » Wed Jun 06, 2018 12:27 pm
will need more information about that product that is at the heart of the issue
if you can provide any screenshots of the issue and such
Postby PlatnumK » Tue Jun 12, 2018 5:24 pm
That error is do to the product using nested instances which reality has a problem with exporting, The only way round this is to use Instances to Objects, but be careful as this can increase you scene size by a large amount (depending how many Instances that needs to be converted)
https://www.daz3d.com/instances-to-objects
