How to make candles translucent
Postby Marcel2586 » Thu Nov 24, 2016 9:26 am
Read the PDF for the explanation.
Here the PDF file.
Translucent candles.pdf
(509.93 KiB) Downloaded 698 times
Re: How to make candles translucent
Postby sigstan » Thu Nov 24, 2016 3:37 pm
Good tutorial!
I'm wondering if you could not use the gradient as an alpha map (opacity) for the candle body. This could be used to make the candle body more transparent in the top gradually going to non transparent. If the light source is the wick, then it should shine through the candle in a convincing way and it would save a light source. It would probably also be easier to set up.
Regarding the Reality translucency option it requires some color math to make it work as expected. I always forget how, because I rarely use it :)
Postby Marcel2586 » Thu Nov 24, 2016 4:56 pm
owakulukem
Postby owakulukem » Thu Jan 05, 2017 9:36 pm
Thanks Marcel
Been trying to get this effect for a while. Thanks for the tutorial.
Postby Marcel2586 » Fri Jan 06, 2017 5:43 am
You are welcome
