Cannot render using my GPU (RX480)
Edna22
Postby Edna22 » Fri Jan 05, 2018 10:06 am
Cannot render using my GPU (RX480) , the render just stays black and GPU load is 0% , using my CPU works fine but I cannot render with the GPU, I have the latest driver with OpenCL™ Version 23.20.15007.1005 , anyone can help?
Daz 4.10.0.123
Reality 4.3.1.16203
LuxRender 1.6.0
Windows 10 Pro x64 1709
brucevanhorn2
Re: Cannot render using my GPU (RX480)
Postby brucevanhorn2 » Mon Jan 15, 2018 1:04 pm
I have a similar set up, so I know it works. Only difference is I'm running with an RX580.
Go into the Scene Configuration, select OpenCL Rendering. You should see a list of OpenCL devices and one should be your RX480 but it's listed as the GPU's chip name. In my case it says Ellesmere. Make sure you check the box. You can also check your CPU box.
I just got this software yesterday, so I'm no expert yet, but it seems like you can pick the threads and it automatically leaves one open. So if you have 8 threads available[image][/image], it'll use 7. That should keep your computer at least marginally responsive while rendering.
