Light Strategies in Luxcore
Postby sigstan » Sun Jul 03, 2016 3:12 pm
Luxcore_light_strategies_v1.pdf
(633.06 KiB) Downloaded 565 times
Re: Light Strategies in Luxcore
Postby Marcel2586 » Sun Jul 03, 2016 3:17 pm
Great! thank you!
Postby Nathanomir » Sun Jul 03, 2016 8:57 pm
Excellent! Thank you.
Postby Nathanomir » Mon Jul 04, 2016 3:33 pm
I threw together a quick test to test this strategy on one of my favorite props from the R2.5 era -- the candle from Faveral's Medieval Tavern. Unlike most 3D candlemakers, he uses a mesh prop for the flame instead of a plane with a transmap. It was easy to convert it to a mesh light and get great ambiance. Lux 1.5 didn't much like it. The mesh slogged down the render time, overriding any increase in speed, and causing massive grain.
Using the above light strategy, and adding the POWER line, this is the result at only 100 s/P (five minutes). At the last second, I threw in some candle glow in Lux.
Lights are just the candle with the flame turned into a mesh light, and one of Lee's IBL spots. The scatter is expected from a scene that is only partially cooked. But overall, it looks like the Medieval Tavern candle is back in action.
So, thank you again, Sigstan!
Postby sigstan » Sat Jul 09, 2016 3:45 pm
Fatbear
Postby Fatbear » Wed Jul 13, 2016 4:24 am
Amazing info, thanks!
Postby sigstan » Wed Jul 13, 2016 6:44 pm
I have added a PDF version of the guide to the original post.
SamWM
Postby SamWM » Mon Jul 18, 2016 5:25 pm
Just a quick question - could you change the light strategy on an already partly rendered file? For instance, do uniform for an hour or so, then change to one of the others? Perhaps for doing a test to see which lights you may want to use for a long render in case you aren't quite sure what to start with, or perhaps just for creative effect
Postby pciccone » Mon Jul 18, 2016 5:31 pm
Nope, if you change strategy then you need to restart.
Postby Kimberly58 » Sun Jul 24, 2016 10:45 am
I have another question, and I'm pretty sure the answer is no, you need to start over. I have a scene that I let render over night only to find I had something I need to modify in the scene. Will I need to export the the .lxs file again and change the light strategy, or will it keep the change since I'm not re naming the file?
