Light Strategies in Luxcore
Re: Light Strategies in Luxcore
Postby Nathanomir » Sat Mar 25, 2017 6:40 pm
I just switched to Windows 10. What program do you recommend for editing an .lxs file in Win10? I get a mess in Notepad, and Wordpad won't let me save it back to itself.
Postby Marcel2586 » Sun Mar 26, 2017 1:40 am
Notepad++
This little program always helps me a lot
Postby Nathanomir » Sun Mar 26, 2017 1:03 pm
Thank you, Marcel.
Postby Marcel2586 » Sun Mar 26, 2017 1:06 pm
Oh, and it is a clean download. do not forget to install the update to be safe
Postby Nathanomir » Sun Mar 26, 2017 5:31 pm
I do not remember downloading and installing Notepad ++ on my old machine, but apparently that's what happened. That is exactly the line editor I was using. So, thanks again.
Postby MustangMike » Sat Jul 29, 2017 10:28 am
Outstanding Niels!
I've been reading the Lux Wiki and documentation and have two questions.
1. Do "maxconsecrejects" and "integer outlierrejection_k" [x] come into play using LuxCore? I know you must be using Metropolis sampler to affect these but only outlierrejection_k shows up in my .lxs file. Do you normally change the value of [x] to something other than 1?
2. What relationship do these two have to each other and is it worth messing with?
With 40 cores in my network rendering I can burn some time to eliminate noise and fireflies. I normally set the outlierrejection_k [5], will anything other than not using LuxCore help?
Thanks, Mike
Postby sigstan » Sun Jul 30, 2017 4:25 am
Postby MustangMike » Sun Jul 30, 2017 4:58 pm
Hey Niels..
Thank you. That's about what I had inferred about the maxconsecrejects parameter.
I know that the outlierrejection_k parameter does work well in Luxrender. I don't change it in test renders using Luxcore but always set it to a higher number than the [1] it defaults to. I normally have a lot of bright/glossy materials in my scenes and experience almost no FF. Since I'm always doing a network distributed render in Luxrender for the final, it's worth it to me to crank up the value.
Somehow I got the idea that the two parameters had "some" connection or relationship but couldn't find anything definitive so thanks for setting my mind at ease. :) Oh, your new RCL v2 is excellent! Thanks again.
Mike
Postby sigstan » Mon Jul 31, 2017 2:57 am
Postby Nathanomir » Sat Jan 06, 2018 7:31 pm
Hey, Sigstan.
Is it possible to add the Power Strategy using CPU-Accelerated, Extra-Boost?
I tried that type of hybrid accelerator last night for the first time, and some point lights I'm using overpowered the scene. So, I added the Power Strategy. Not too successfully. The LXS file for that type of acceleration looks totally different from the regular CPU-Accelerated.
Here's my actual file, and you can see where I added the Power option.
Luxrender didn't know what to do with that.
