G3F and Iray skins
andrewd084
Re: G3F and Iray skins
Postby andrewd084 » Mon Jul 18, 2016 11:55 pm
So I know this isn't why you posted the thread, but I have to ask (because I've been trying to figure it out myself) - how did you get the backgrounds transparent? It looks a lot better than just chopping sections of the image out in photoshop.
Postby pciccone » Tue Jul 19, 2016 12:06 am
You just enable "Transparent BG" in the Render options of Reality.
banditcameraman
Postby banditcameraman » Tue Jul 19, 2016 12:09 am
I checked the "Transparent BG" box: and that works if the background is IBL and there are no geometries behind the character, not even a plane ;) :mrgreen:
Ack, ninja'ed :lol: ! what Maestro Paolo said :oops:
Porphyrogenitus
Postby Porphyrogenitus » Sat Nov 05, 2016 6:54 pm
One thing that happened in some of your renders is happening with mine, in that the materials seem to have a light purplish-blue cast to them.
I have bought the V7 presets and used that also. I don't get the effect with older materials such as V6/G2 character surfaces.
Do you have any tips on how to fix that?
banditcameraman
Postby banditcameraman » Sat Nov 05, 2016 11:19 pm
Hi Porphy, I think I know what you mean :geek:
Leave the settings for the Lips as is and try using the earlier recipe for specular on the body: Specular map > texture combine > multiply > select Image Map and choose the same specular map for texture B, then edit texture A and choose texture combine and add the color settings and do the same for texture B. Here are the colors (it's from an earlier version- Color Math is now Texture Combine :geek: )
Here are some results using those specular settings:
Hth! :ugeek:
PS. Personally I prefer to use the lighter Bump map n Texture A and the darker Specular map in Texture B but you can keep it simple 8-) ;)
Porphyrogenitus
Postby Porphyrogenitus » Mon Nov 14, 2016 2:40 pm
Thanks, I'll try those!
