I tried to re-install Reality 4.3 in Poser Pro 11.2.272
When I start Poser, I get this message:
An errror occurred importing addon Reality : ERROR: need more than 3 values to unpack
The Reality option does not appear in the Render dropdown menu.
Seems to be a python script thing; everything worked fine in Poser 11 Standard (latest version) before the upgrade to Poser Pro.
Is there anything I can do to fix the problem?
Should Bondware fix it?
Is an update of Reality necessary?
Windows 7 Pro 64 English, DELL T7400 Workstation, Dual Quadcore Xeon E5450, 36GB RAM, Zotac GeForce GTX 1050 Ti Mini, Poser 11.2.272 Pro 64 Bit, Reality 4.3.1.16203 - 64 bit
Poser is going up in version number.
Re: Poser is going up in version number.
I'm having the same issue
tsoren, were you able to correct the problem with Reality?
There's a thread about it at Renderosity. Snarlygribbly is working at a fix, adjusting the way python starts up.
I'm beta-testing it and I got Reality running again from Poser 11.2.
The script fixes problems with several older Python-based plug ins.
If nothing goes wrong the fix should be available in a few days.
From the forum link here it will probably be part of the next Poser build, but the current build can be fixed easiily with Snarly's patch.
Yes! And that's wonderful news!!!!
That Snarlygribbly fix works for me too.
The fix (for Poser Pro 11.2 rather than Reality) can be found here:
https://www.poserlounge.nl/PLWP/
With many thanks to Snarlygribbly.
Now here's one more trouble to shoot.
Where is Paolo?
Where is Paolo?
