Never had this problem before. Downloaded the most recent update, and it won't install. I get this error:
The configuration file /private/var/folders/xn/lm2q8kwn0lzcxbbwvlgq4c600000gn/T/AppTranslocation/B06640D8-DB1F-41A2-8C9D-B82484A79EE4/d/RealityInstaller.cfg is missing. This installation cannot continue.
Mac OSX 10.12 (Sierra).
Problem installing Reality 4.3 (OSX)
Re: Problem installing Reality 4.3 (OSX)
Sorry, but Apple has broken compatibility with 10.12.0. Please try 12.10.1, hopefully they fixed it.
Um . . . could you give some details as to what you think is broken here?
Not sure how to get help from Apple support; other installers seem to work OK with 10.12.1, but Reality does not, so the response I get from them Apple boards "nothing wrong on this end".
since Reality was not changed and Mac OS was, it's clear that the breakage happened in Mac OS. The same issue has been seen with other programs. Apple has botched this release. Ask an Apple Store to re-install El Capitan on your machine.
Or Right Click on the RealityInstaller.app and select Show Package Contents, Then Navigate to Contents/MacOS and Right Click on the RealityInstaller and select Open so that the installer runs from the terminal
this works for Poser as well as Dad studio.
In Poser make sure that you are pointing to 64bit and not 32bit folder.
