Just installed, lights not working
twall
Postby twall » Sat Oct 13, 2018 11:18 am
Hello,
I just installed Reality 4.3.1.16203 for Daz Studio. I've used older versions of Reality before. I tried a test scene, as it's been a long time since I've used Reality, and was getting an error: Severe error: 46] No light sources defined in scene; nothing to render in LuxRender.
I have made a test scene with two primitives in it, one is a cube, one a sphere. I made one camera.
In Reality, I converted the sphere's texture into a light. It shows up in the lights:
Reality "knows" there's a sphere and a cube in the scene:
But when I tell it to render the frame, it doesn't export the light. Here's the entire lxs file:
# LuxRender Scene created by Reality by Pret-a-3D
# Camera: Camera 1
LookAt 1.45 -3.7 1.9 1.44637 -3.691 1.89758 -0.000906255 0.00224306 0.00970296
Camera "perspective" "float fov" [30.9573] "float screenwindow" [-1.77818 1.77818 -1 1]
Film "fleximage"
"integer outlierrejection_k" [1]
"integer xresolution" [978]
"integer yresolution" [550]
"bool premultiplyalpha" ["false"]
"string filename" ["reality_test001"]
"float gamma" [2.2]
"integer displayinterval" [15]
"integer writeinterval" [60]
"string tonemapkernel" ["autolinear"]
"bool write_png" ["true"]
"string write_png_channels" ["RGB"]
"bool write_png_16bit" ["false"]
"bool write_png_gamutclamp" ["true"]
"bool write_tga" ["false"]
"string write_tga_channels" ["RGB"]
"bool write_tga_gamutclamp" ["true"]
"bool write_exr" ["false"]
"string write_exr_channels" ["RGB"]
"string write_exr_compressiontype" ["ZIP (lossless)"]
"bool write_exr_gamutclamp" ["true"]
"bool debug" ["false"]
"bool write_resume_flm" ["true"]
"bool restart_resume_flm" ["false"]
"bool write_flm_direct" ["true"]
"float colorspace_white" [0.314275 0.329411]
"float colorspace_red" [0.630 0.340]
"float colorspace_green" [0.310 0.5950]
"float colorspace_blue" [0.1550 0.0700]
"string ldr_clamp_method" ["lum"]
Renderer "sampler"
PixelFilter "blackmanharris" "float xwidth" [1.5] "float ywidth" [1.5]
Accelerator "qbvh" "integer maxprimsperleaf" [4] "integer fullsweepthreshold" [16] "integer skipfactor" [1]
Sampler "metropolis" "float largemutationprob" [0.40] "bool usecooldown" ["false"] "bool noiseaware" ["false"]
SurfaceIntegrator "bidirectional" "integer eyedepth" [16] "integer lightdepth" [16] "string strategy" ["auto"]
VolumeIntegrator "multi" "float stepsize" [1.0]
WorldBegin
# Textures
# From channel Ka
Texture "pCube_11cg000_1_8-28152:Default:Default_Ka" "color" "constant" "color value" [0.875135 0.875135 0.875135]
# From channel Ks
Texture "pCube_11cg000_1_8-28152:Default:Default_Ks1" "color" "constant" "color value" [0.015396 0.015396 0.015396]
# Volumes
MakeNamedVolume "air" "clear" "float fresnel" [1] "color absorption" [0 0 0]
# Materials
MakeNamedMaterial "RealityNull" "string type" ["null"]
# Mat: pCube_11cg000_1_8-28152:Default (Glossy)
MakeNamedMaterial "pCube_11cg000_1_8-28152:Default" "string type" ["glossy"] "texture Kd" ["pCube_11cg000_1_8-28152:Default:Default_Ka"] "texture Ks" ["pCube_11cg000_1_8-28152:Default:Default_Ks1"]
"float uroughness" [0.3]
"float vroughness" [0.3]
Include "reality_test001.lxi"
WorldEnd
# End of scene
It's like the sphere disappeared alltogether. I've tried it with mesh lights in the scene, too.
I am using Daz Studio 4.10.0.123
Could you help troubleshoot?
twall
Re: Just installed, lights not working
Postby twall » Sat Oct 13, 2018 11:25 am
LuxRender version 1.6.0 which I assume came bundled with Reality
jbirchett
Postby jbirchett » Sun Oct 14, 2018 5:44 pm
I did the same thing and it worked fine for me. Not sure what's going on with your setup. I have had to quit Reality/DAZ Studio and reload a scene before because an object wasn't getting sent to Lux, though. Have you tried that?
twall
Postby twall » Sun Oct 14, 2018 9:58 pm
I appreciate you trying it, I don't know why it's not doing the lights for me.
I have tried quitting both Reality and Daz Studio and reloading, it doesn't help. For some reason, it seems that the lights are not being included in the lxs file.
I'm wondering if I should uninstall/reinstall or if someone from pret-a-3d has any thoughts on what's going wrong here?
twall
Postby twall » Mon Oct 15, 2018 6:14 pm
Just bumping, hoping I can use Reality. Don't know why the lights aren't being included, sure could use some help.
Postby sigstan » Tue Oct 16, 2018 2:00 am
Make sure you do not have the light parented to the camera, since that would make it invisible. You could also try with an IBL instead of a mesh light.
Most likely though, this is a Reality install problem.
Since you have had earlier versions of Reality installed, I would try a uninstall followed by a re-install of Reality.
You can find how to un-install Reality here: . Make sure you have no previous Reality installations left, before proceeding to install. This will insure that you do not end up with a mix of different Reality versions.
For the re-install it is best that you choose the defaults suggested by the installer.
Please note that you do not have to re-install DAZ studio, since it is a major hassle and have never provided a solution to any Reality-related issue as far as I know.
twall
Postby twall » Wed Oct 17, 2018 11:56 am
Thank you, I will try that.
Users browsing this forum: No registered users and 7 guests
