DAZ Studio Fatal Error on Startup with Reality Installed
jbirchett
Postby jbirchett » Thu Jan 04, 2018 1:10 am
Re: DAZ Studio Fatal Error on Startup with Reality Installed
Postby pciccone » Thu Jan 04, 2018 9:54 am
Sorry for the inconvenience. This issue could be caused by either Av or Firewall software blocking Reality from making a connection. For this configuration to work both DAZ Studio and Reality must have unrestricted inbound/outbound Internet access. This is because Reality uses TCP/IP (Internet) connections to exchange information between Studio and itself.
Check your AV/Firewall configuration and modify them if they restrict any Internet traffic with both DAZ Studio and Reality.
jbirchett
Postby jbirchett » Thu Jan 04, 2018 6:44 pm
Thanks! It's working now and it was definitely the Windows 10 firewall, but I don't know what was wrong. I had no rules blocking Reality. I enabled the Windows 10 firewall logging functionality for dropped packets and started DAZ over and over, but nothing ever showed up in the firewall log except UDP and multicast traffic, none of it sourced from my desktop. I disabled malwarebytes and that didn't do anything. I disabled Windows firewall and suddenly, DAZ Studio worked again. I enabled Windows firewall, determined to find the offending rule, but DAZ Studio kept working after I turned the firewall back on. It makes no sense, but maybe it will work for someone else who encounters this bizarre issue.
Postby pciccone » Thu Jan 04, 2018 6:52 pm
Hey, t least you found the source of the issue. Now, commit that to memory in case this comes back after one of those delightful Windows updates ;)
Thank you for letting us know.
jbirchett
Postby jbirchett » Sat Jan 13, 2018 7:23 pm
After a reboot tonight, the error is back. I can only use DAZ Studio if the Reality plugin is gone from the plugin folder. I disabled Windows firewall and Malwarebytes, but the error won't go away. I guess it was something else. I tried various things to fix it tonight, but I'm shooting in the dark and I have no idea what to look for. Network access is unfettered. This is not even the first time I've rebooted since it started working again, so it could be something installed in reality (custom .rsbs from the forums?)
I'm done using up my weekend on this, so I'll come back to it again when I have some more time to kill. Any advice is greatly appreciated.
Postby sigstan » Tue Jan 16, 2018 2:04 pm
Have you checked, if by any chance your AV has put some Reality files into quarantine? - Norton once pulled a stunt like that on my machine.
Otherwise it sounds really strange that Reality could go from working to producing a fatal error without any changes.
jbirchett
Postby jbirchett » Wed Jan 17, 2018 12:42 pm
Yeah. I've completely reinstalled DAZ Studio and Reality, including cleaning out the registry. All of the files are in place. I've tried running DAZ through Windbg to see if I can see where it's failing. There is a gethttp executing when the crash happens, but there's nothing being blocked that I can find. I thought it might be my Internet firewall, so I used my phone to tether without any local firewall or AV running, but it still crashes. I also tried using wireshark to capture traffic, but I don't know what to look for, so that's a needle in a haystack. Whatever it is, it's during the initialization of the plugin. There is also some OpenCL stuff around the same time. I tried using rawcap to sniff traffic on the loopback adapter, but didn't see anything there, either. I think my "fix" is going to be a system reinstall. Until then, I'm just delting the Reality dll and using Iray. I've been playing with the LAMH catalyzer and some AM figures since I can't use luxrender right now anyway.
Postby sigstan » Thu Jan 18, 2018 2:25 pm
I would not consider doing a system re-install. I have never come across any problem with Reality that required this, at least not under Windows. The same actually applies to DAZ re-installs. If you have a fully working DAZ-installation before installing Reality, then any problems with Reality is more likely to have other causes.
Some of the major Windows updates will wipe the OpenCL drivers (I believe Windows 10 Fall Creators Update did this), so try installing the latest OpenCL drivers for your CPU-type, and also make sure you are using the latest GPU-drivers for your GFX card.
Only other reason I can think of would be, that you installed another DS-plugin that conflicts with Reality. There have been previous incidents of this, but it was a long time ago.
jbirchett
Postby jbirchett » Sat Jan 20, 2018 12:12 am
I came back to post the latest update and saw your post, which was on point. I had decided to tackle the video drivers before doing a system reinstall, so I fired up Nvidia GeForce Experience to reinstall my current driver - and hopefully fix any OpenCL driver issues - and noticed there was a new driver on 1/8 that I had not yet installed. I installed the video driver, rebooted, and Reality is now working again. Hopefully, that was the issue. The only other plugin I have that's not DAZ is LAMH catalyzer and I had already tried removing that because I had the free player and the catalyzer and thought maybe they were conflicting and throwing the error down the stack.
If it stops working again on the next reboot, I'll assume there's a hidden flag in my CPU that toggles every reboot to mess with my mind.
