Cant access Reality 4 from Daz studio
Discussions on DAZ Studio techniques
david2169
Postby david2169 » Mon Jan 02, 2017 8:41 am
Hi
A few days ago I decided to change the view on Daz studio. I did that no problem but when I selected render to access Reality 4 it didn't show anymore. I have since been on the Daz studio forums trying to figure out how to restore things to normal, so far without success.
I actually removed both Daz studio and Reality after a few attempts at different things. My reasoning being that a clean start might help. So I downloaded a new DS installer and the same for Reality and went through the process of installing them both once again. Everything appears as it should as can be seen from the Reality installer and Daz Studio resides exactly where it should as well.
I have Reality actually in my applications folder with a link on my desktop which I added when I opened the app manually from the apps folder. So I can render using reality and Lux by opening Reality from the desktop, but there is no way to do this from within the Daz studio app.
Everything worked fine until I changed the view option, and in all honesty I think this is a Daz issue, but who knows, maybe you can offer some solution.
Many thanks
david2169
Re: Cant access Reality 4 from Daz studio
Postby david2169 » Mon Jan 02, 2017 8:55 am
Cant quite see how to attach images but I will keep looking before posting this. Additional info. The Reality plug in is definitely in a folder named Reality inside the Daz studio plug in folder so thats fine. The reality plug in shows in the installed plug ins list and is ticked as active...
Gosh adding attachments suddenly got really simple, so I think thats pretty much the situation, any additional info I can supply please let me know...
Many thanks
Postby pciccone » Mon Jan 02, 2017 8:59 am
Have you tried the keyboard shortcut? Cod-shift-Y?
david2169
Postby david2169 » Mon Jan 02, 2017 11:11 am
I have tried the shortcut you mention with no result...
Also tried others, any port in a storm so to speak, nothing seems to work...
Postby sigstan » Tue Jan 03, 2017 3:25 pm
Try switching the Studio layout (Window/Workspace/Select Layout) to something different than the current one and then switch back to your favorite layout. That should reset the menu.
david2169
Postby david2169 » Tue Jan 03, 2017 5:56 pm
That did the trick, thank you so much.... :D
Postby Marcel2586 » Wed Jan 04, 2017 9:59 am
Postby sigstan » Wed Jan 04, 2017 4:26 pm
sanaeerumey
Postby sanaeerumey » Sat Nov 10, 2018 4:29 am
Return to “DAZ Studio”
