Installing Reality on MacOS Sierra 10.12.1
Postby PlatnumK » Thu Nov 17, 2016 6:01 am
As you may have noticed that a few people have been having problems getting Reality 4.3.1.16203 to install on MacOS Sierra 10.12.1 and each time they get the following error
After many hours trail & error, And liaison with Paolo I believe that I have found a solution, It has to do with the way MacOS Sierra handles File Permissions. As many have found that Apple in their infinite wisdom decided to remove the ability to fix permissions from the terminal.
At 1st I thought that the problem lies with the RealityInstaller.app but not so. The problem is with the Permissions on the DMG File, So if we can no longer fix the permissions from the terminal then how do we correct this particular problem.
1. Open the DMG file as per normal so that it mounts as a virtual disc
2. Close the window that pops up that has the RealityInstaller.app in it
3. Open Disk Utility and select the Reality Installer Disc from the last on the left, Then click on First Aid
You should now be able to run the RealityInstaller.app without any problems. Hopefully you will find short guide this helpful, And please let me know if this works as I don't have access to another Mac to test this out fully.
Re: Installing Reality on MacOS Sierra 10.12.1
Postby pciccone » Thu Nov 17, 2016 7:21 am
Daniel, thank you very much for this. I will look into this and possibly update the DMG file.
bca
Postby bca » Sat Nov 19, 2016 7:18 am
Thanks for providing this workaround. Unfortunately, it didn't work for me. When I run First Aid on the dmg file the log shows no problems were found and no changes to the dmg were made and I still get the missing configuration file message. I'm unable to install Reality.
Postby PlatnumK » Sat Nov 19, 2016 11:30 am
Try this https://support.apple.com/en-us/HT205331 (just do step 8) then reboot and try again,
Or Right Click on the RealityInstaller.app and select Show Package Contents, Then Navigate to Contents/MacOS and Right Click on the RealityInstaller and select Open so that the installer runs from the terminal
mwcsb
Postby mwcsb » Sat Nov 19, 2016 1:01 pm
Postby PlatnumK » Sat Nov 19, 2016 2:23 pm
Your welcome
bca
Postby bca » Sun Nov 20, 2016 8:51 pm
Indeed, the terminal installation worked. Thanks for figuring this out.
MrWizard1024
Postby MrWizard1024 » Sat Dec 24, 2016 6:01 pm
Many thanks to you, mwcsb, for helping me make this work. The terminal installation was the only thing that I could get to work. And it worked like a charm!
Postby pciccone » Tue Feb 28, 2017 11:49 am
Made this thread Sticky
Jeffk
Postby Jeffk » Sun Jun 04, 2017 9:02 pm
I've tried everything mentioned here and I still can't install under MacOS 10.12.5. Same error message no matter what...
