Installation Error: Configuration file missing
effin_smartass
Postby effin_smartass » Tue Jun 04, 2019 7:50 am
Hello. I've just purchased Reality 4.2.1 for Daz Studio 64-bit version 4.10.0.123, running on MacOS Mojave 10.14.5 (18F132). When I double-click on the RealityInstaller.app, I get the following error (this is copy and pasted): "The configuration file /private/var/folders/wv/4ncflbys31v4jls9tgjpt2d40000gn/T/AppTranslocation/5B993742-64E1-4ABB-B3D7-2E5125C62CC4/d/RealityInstaller.cfg is missing. This installation cannot continue."
I have attached a screenshot.
I haven't seen any similar posts, so please tell me how to correct this. Thank you!
Re: Installation Error: Configuration file missing
Postby pciccone » Tue Jun 04, 2019 7:56 am
This issue is caused by Apple breaking compatibility with past applications. Fortunately there is an easy workaround. Please see this post:
viewtopic.php?f=23&t=660
effin_smartass
Postby effin_smartass » Wed Jun 12, 2019 9:39 am
Tried this and it did not work. Tried deleting and re-downloading, re-starting, and other obvious steps along with your linked work around, and it's still doing the same error. Please let me know whether you have another solution. Thanks
Postby PlatnumK » Thu Jun 13, 2019 5:46 am
Try this, 1st launch the Terminal, Next Right Click on the RealityInstaller.app and select Show Package Contents,
Now Navigate to Contents/MacOS then Click on the RealityInstaller & drag n drop it onto the Terminal Window, Click on the Terminal Window to make it selected & press Return to run the Installer.
