Hi, I did the terminal installation process and worked perfect, until the Reality installer opened, then it prevented me to continue with the installation. I can only see the Previous and Quit buttons active, won't let me press INSTALL. I am stuck right after reading the license agreement and pressing next, then the installation folders are automatically filled out. But neither Next or Install buttons are active.
Any suggestion?? Thanks. I'm on Mac Mojave
Installing Reality on MacOS Sierra 10.12.1
Re: Installing Reality on MacOS Sierra 10.12.1
Can you post a screenshot of the window?
Ok, that means that the installer could not find DAZ Studio in the location that you have selected. Double-check, find the right location and you should be all good to go,
Actually, let me make a correction. As we can see from the screen, you are trying to install reality 64-bit, but you are pointing to DAZ Studio 32-bit. That can’t be. The bigness of the programs must match.
So, either install Reality 32-bit or point the installer to the 64-bit version of DAZ Studio.
Cheers
Cheers
awesome!! that did the trick, I just had to select the DAZStudio4 64-bit folder. Thanks.
One last thing, do you know why I am being unable to save my scenes? Im on a mac and each time I try to save first the window appears behind the DAZ Studio window, so I have to minimize DAZ in order to see the save window. Then no matter what name I choose for the scene it always overwrites the file and changes the dame to something like documents.duf or daz.duf so if I create a new scene and save it as a new one it will overwrite the previous one and I will loose my previous project.
Sorry, I wouldn't know about that. Probably best to all that question on the DAZ Studio support forum.
thanks for your help! have a great one
The workaround detailed in the post above (running from terminal, i.e.) worked for me in Mojave. Thank you
