Differences
This shows you the differences between two versions of the page.
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
removing_the_reality_data_from_a_scene [2016/01/04 05:37]
pciccone created
removing_the_reality_data_from_a_scene [2016/01/04 05:55]
Line 10: Line 10:
 For example, if at the end of the file you see: For example, if at the end of the file you see:
-<nowiki>+<code>
Line 27: Line 27:
-</nowiki+</code
-You will want to delete from the beginning "​a"​ of "​addonData",​ all the way to the the matching "​}"​. ​Whi will give you the following+You will want to delete from the beginning "​a"​ of "​addonData",​ all the way to the the matching "​}"​. ​The result that you should obtain is
-<nowiki>+<code>
Line 42: Line 42:
-</nowiki>+</code>
removing_the_reality_data_from_a_scene.txt · Last modified: 2016/01/04 05:57 by pciccone
Driven by DokuWiki Recent changes RSS feed Valid CSS Valid XHTML 1.0
